Operation shop rehab
Outside is coming along nicely got all the trees I didn't want to drop myself took out today
Day one to now still need to finish burning this pile of trees and brush and one more small pile around the corner of the building. Tear down the single while plant grass seed and gravel the driveway but the outside has come along way. Only thing left to do inside is install the air compressor and run lines and add another 220 plug for a welder at the front.
I saw the smoke pic before I read the post and thought it was blue gender reveal smoke 🤣 I thought, damn, that dude got on down to business
Today progress so far. Cut down some trees on back side of shop and cleaned that area up. Also found a trailer to threw all the scrap I came across on it as I was going. Most of these areas you couldn’t walk though Friday afternoon.
I now have two scrap piles this size plus the trailer full of scrap and two other small trailers, I haven’t even started on the inside.
Also free to a good home 60ish ft single wide packed full of push mowers.
what is up with that small camper in pic number 4
Shop light number 2 installed let's see how long this one last.
Also finished redoing the compressor I found in the building with a new 230v motor and all new parts except the tank and the air head that from what I can tell Is from the 50s. Installed a 1/2" air shop kit from Northern tool. Well worth the 100 bucks for the easy fast install. Holding up well to the 170lbs the compressor is set to. Added two more lights inside to get all the way to the back of the shop. Tried to chase down the leaks and released I'm going to have to coat the whole outside to take care of all of them. But after that the shop should be set for a while.
Well the single wide is gone..... almost just have to haul the metal and burn the wood that's still there most had about rotted away and no insulation in it
Whats with the camper?
