paulevans76
- Mar 21, 2005
- York, SC
I've got a fun beater trooper trail rig. I still drive it to and from the trails and usually it does pretty dang good. But there are issues I've been wanting to deal with since the first time I hit the trail with it in its current form.
It's currently got a "hot" 3.4l GM v6 making probably 185hp-ish. Trans is the stock Isuzu MUA5 with aftermarket 3.07:1 gears in the tcase. 5.38s in the axles and 35" tires for now. It does fine everywhere but technical crawling - I have to 3 foot it, and beside that annoyance in itself, sometimes I'm worried I'm going to break something, since the throttle is so touchy in low/1st as I'm doing a shitty job trying to feather it through stuff. I'd like to get where I can throw it in low-1st and just concentrate on steering and maybe just 2 pedals.
If I had a diesel with all the torques hitting at idle, it would be fine, but I don't. I think if I had an auto with the same low range, it would probably be fine as well.
I'm not going to drop a diesel in it, but I do have a 700r4 I could use. I could somewhat easily have an adapter made to an isuzu case with the 3:1s. I also have a line on an already set up isuzu dual transfer case unit, or I could do my own (more downtime though).
With the 700r4 + 3.07 case, I'd be at about 50:1 in low + the torque converter factor
With the duals, depending on case ratios, I could be anywhere from ~95:1 to ~130:1 in low/low
I plan to run 37-38's eventually as well.
I like that with the auto, you can work the brake and gas to crawl easier, and you can also wind it out for a bit more wheelspeed while still in low. But I don't like that the swap would be more involved, and I'm also worried that every burnt out vehicle picture I've seen has a story about ATF leaking on exhaust.
The drawback to the duals is that the crawl box case in front has only about a quart capacity and can heat up on the highway pretty quick, although there are some mods and mitigating actions that could be done to help.
Both would require driveshaft changes, but that would be welcomed because currently my front is only about 24" long and binds after about 4" of droop.
What say you folks that have had both type setups?
