Webbinator
- Mar 20, 2005
- York, SC
Yep, you heard me right. Got it running this afternoon. This is on a 258 in my CJ7. It fired right up on the first turn of the key. Did have to do some minor adjusting on the idle but other than that, it ran beautifully. I did have to deal with a few leaks at some of the connections but I worked them all out. And yes, I fixed the leaks BEFORE I tried to fire it up. I do still need to give it a test around the neighborhood to see how it does under load and excelleration. Can't do that until I get the rear brake line reinstalled and bled. I'm also finishing up swapping in some rear XJ springs for extra wheelbase. All I need to do on that little project is to build and install a traction bar to help control spring wrap. Other than the brake lines that is. It truely never ends.
