6BangBronk
- Jul 15, 2005
- Durham
I'm lost and need direction. I'm trying to figure out if my plans for a 460 on my rig will work with pane. I purchased a Impco 425 mixer and regulator but have researched that the CFM is around 450 max. That ain't going to cut a 460 appetite without starving itself and not ever running right under any mixture? Is dual propane mixers even a logical option? Or should I just consider gasoline. I'm finding that 750 cfm is perfect for a 460. Anyone ever heard of dual mixers? Or should I just stick a carb on there and be done with it? If I go dual pane, should I use 2 smaller mixers to yield around 700-750 cfm?
Anyways I have already prepared for the 105 octane by putting flat forged pistons in and had plans for replacing valves with ss and have already recurved the dist. And yielding around 11.5:1 compression with my heads shaved. But I do have another set of heads to lower the compression if I decide to go with gas.
Rig is a 76 F-250, D60/14 w/ 5.13's no bed but full cage - estimating around 3,500 lbs worth. I would consider a 351W I'm building but I don't think it would be nearly as capable for a full size rig as the 460? Haven't bought tires yet. Would probably go 37 or 39's if I go with the 351W. 39 or 42's with the 460.
Any input? Alot of time and money at risk to turn back now!
