Performance Transmissions
sha_ba_do_bang
Joined the Band
Banned
Wilmington
All transmissions are fully rebuilt. All seals, bands, gaskets, clutches, steels, sprags, are replaced. Solenoids and sensors are tested and replaced if needed.
Turbo 350: red eagle clutches, performance bands, HD reprogramming kit(your choice of full manual control or auto, holds gears to any rpm). Good for 450+ horsepower $750
Turbo 400: red eagle clutches, performance bands, HD reprogramming kit, updated pump gears, 34 element sprag (instead of weak spring and roller), hardened input shaft and input drum. Optional full race stick shift control, holds 1&2 to any rpm, downshift 2-1 at any rpm $800
700r4: red eagle clutches, performance bands, HD reprogramming kit, "the beast" monster shell, hardened input shaft, 2nd corvette servo, up and down shift to any gear, optional manual control $1000
4l60e: red eagle clutches, performance bands, HD reprogramming kit, "the beast" monster shell, hardened input shaft, 2nd corvette servo, up and down shift to any gear, optional manual control, new pressure control and shift solenoids $1200
4l80e: red eagle clutches, performance bands, HD reprogramming kit, updated hardned input shaft and bushing, 34 element HD sprag, compression braking in any gear, optional full manual control, upshifts at any rpm $1800
46,47,48re: dodge trucks 89-06. red eagle clutches, performance bands, HD reprogramming kit, updated hi-temp low shrink rings, updated overdrive thrust washer, competetion shifts, down or upshift at any rpm. The problematic govenor control solenoid and sensor is ALWAYS replaced(#1 cause for dodge transmission failure). $1200
These are our most popular transmissions, we also do all ford transmissions and many others on request. Foreign or Domestic
These are performance built transmissions with a one year warranty. I'll even take it back out if you bring the vehicle back to me if you have a warranty issue!
Prices provided a buildable core.
We also do shift kit/valve body and torque converter upgrades.
