Pertronix
upnover
Grumpy, decrepit Old Man
Moderator
Morganton NC
I got a pertronix igniter to replace my points in My Heep. Good instructions, went together pretty easy. Will try it out at Tellico this whole next week. Cranked up and seem to run very smooth from the get go.
Carrying my old points, just in case
Pertronix has been around for a LONG time, converting points ignition to electronic before the manufacturers ever did.
Early models used an optical system with a light and pick up and a breaker wheel (very similar to the guts of an old mouse) new uses a hall effect pick up.
I used one of the early models on my VW dunebuggy WAY back when. worked well.
Few weeks ago I ran into an issue with a set up that had been installed on a forklift. stock ignitor died, they bought a Pertronix to replace it (cheaper) .
They could not get the engine to run, and my company sent me to check it out.
I found that I could get it to run if I retarded the timing all the way to stop and disconnected the vacuum advance, but it wouldn't run well. tried to move distributor one tooth either way wouldn't run at all then, ????
Took the parts out and looked at them close, then I noticed the relationship of the flat on the dizzy to the magnets on the ring supplied with the Pertronix unit.
For a 4cyl, the magnets are spaced every 90*, and these infact were, BUT, the the magnet circle was turned 45* from the flat of the dizzy causing the timing to be VERY late or WAY too early thus not letting the engine fire.
Asking the owner of the machine for the original parts, ( which, smartly he had kept) I verified this with the stock magnet ring, sure enough, the magnets were inline with the dizzy flat.
Not wanting to chance the same problem with another Pertronix set (could have been a misbox, or production mistake) I ordered the proper factory ignitor ($$$) , truck runs fine, better than it had in years accoring to the guy that drives it.
Something to keep in mind when dealing with aftermarket parts, they aren't always perfect.
Ive run a pertronix Ignitor II on my '65 stang for ~7 years.
Great. Reliable. No complaints.
I also bought their coil. After 3 of those shit on me in 1 year,:rolleyes: I replaced with a accel piece and have loved my ignition ever since
All the peepster guys with 225V6s rave about them... many also rave that the Pertronix have & will die, so be sure to carry a good set on uni-points just in case...
I found it pretty simple to ditch the points in favor of DuraSpark II... got about $100 in it... definitely aq big difference in both ease of starting & overall performance over points!
I have installed several with good results over the years.
I've also had bad factory parts, and stock replacement parts.
If you replace/upgrade/change enough over the years it will happen.
I put a pertronix set up on my 68 Mustang 289 V-8 and it worked perfectly. I always left a new condensor and points in the glove box anyways, so I just left them in there.
I sold the car a few months ago and it was still working fine. I don't think you'll have a problem, but better safe than sorry to keep the points/condensor with you.
Points+condensor=$5 worth of parts that can make you walk 5 miles
Spare points and condensor in glove box = $5 worth of parts that keep you from having to walk 5 miles:rolleyes:
