crazydwayne23
- Mar 15, 2010
- Kings Mountain
ok i just recently bought a 93 wrangler.
that has had a coil spring conversion kit put on it that makes the rear axle have a four link system, i noticied that the rear pinion looked like it was pointing at the sky, so i adjusted the cam bolts in the four link to correct it , pinion is at a much straighter angle now, but now at 45mph i have a vibration / low roar noise. is it possible the drive shaft has been changed with one thats got a longer yoke at tcase? or does the np 231 t case have that $10 snap ring inside the tailshaft that hold the tailshaft off the chain, & it has broken? any ideas what my problem is???
