Pit man arm?
hutch98
Member
Winston-Salem
Is there any place in the Carolinas that make custom pitman arms?
Thanks for the help
Hutch :beer:
a perfactly flat arm, or one with some drop in it? be more specific.. I may know someone local to ya.
pit man arm
lenth from center to center of the holes about 5 3/4" and 3/4 to 1" max drop for a toyota with a tapper for a chevy 1ton TRE. Used a flat arm from sky manufacturing 1st made it 2" shorter which I had no turning radius so we took the cut part re-welded it with a @ 3/4" drop and the turning radius is perfect and moved the axle back 1". Anything over a 1" drop will bind up the x-over steering.
Thanks again
Hutch
