Please help, crazy vibration
49erRider
Indian Land
alright so i drive a 1989 dodge ramcharger 4x4 and i'm driving down the road the other day and all of a sudden i get this crazy vibration sounds as if its coming from the rear but since i'm kinda new to all this stuff no idea of what it is. The steering wheel and entire car will vibrate but this has never happend before. Happens when i get around 25. Any help and detailed answers would be greatly appreciated. thanks
does it do that continually afterwards up through higher speed or just at 25?
you may have slung a wheel weight off
or you may be losing a u joint I had a ford van that had the u joint cap coming out vibrated like crap after 35mph one of the straps was loosened up on it. so you may want to check your u joints as well.
have someone drive behind you while it does it and see if they can see which tire (if any) is causing the problem.
also check all your lug nuts for tightness
anyone in the south charlotte or charlotte area have a little bit of time to spare helping with the install of new u joints just wondering would be much appreciated
Ujoints are really easy. I"ve used everything from a hammer to a c clamp to install em. Just use a BFH and knock the old ones out.
