now I advise getting cellular core schedule 40 pvc pipe.It is not for pressure yet wont deform underground.It is cheaper than standard sch. 40 pvc too.
Your bends will come in at 22.5,45,90 degree bends.Make sure your bends are for sewer and not for pressure,The wider the bend you do,the better it will be.A 90 bend itself is way to short asnd should be used only to turn up at a cleanout point behind a bend in the line.If you do a 90,use what is called a combination wye.It will give you a long sweeping bend and out the backside you can do a standard pvc sewer 90 and turn it up for a cleanout.If you don't want to do a cleanout at this point,use 2-45 bends and about 8 inches of pipe to do the turn.Depending on what you have to turn to get out from the tank will determine the number of bends and what degrees they are.If you are lucky,the tank is to one side and you can cut out the existing bend and run straight on.If not then you will need to plan it.If you have 4 inch cast iron coming out the house,use a 4inch CI/4inch CI fernco to tie your plastic in.At the house,Install a 4inch pvc wye that is swept in both directions as the cleanout closest to the home.You can rod both to the street and back under the house.In Goldsboro,a cleanout will be installed every 75 feet on a 4 inch line.Use a pvc combination wye at these points.Hopefully you will only need the one at the house and the existing at the ROW.
You will either glue a connection at the ROW cleanout or if they use CI,you will pull the plug out the back of their comb. wye and push in a pvc female adaptor.
