dae03TJ
- Jan 29, 2008
- Wilmington, NC
When i am going below 20mph and make a right hand turn ( left front wheel accelerating faster then right), the front left wheel makes a bad popping sound, but only when power is being sent, no issues in neutral. the whole jeep jumps, and i am hearing a slight squeaking during driving. the jeep also pulls to the left at higher speeds. is this a wheel bearing issue, u-joint, or axle shaft? i am hoping its just a wheel bearing or u-joint, its a cheap fix. front axle is a d30. just replaced wheel bearing 4 months ago, but it was the cheap one from advance auto. Thanks for the help.
