Will Carter
- Mar 23, 2005
- Burlington
RufusTheRam said:that what you were working on friday night? thought about pulling in and being nosy, but then the 105/421 light turned green.
wcialrlter said:CUCV hubs will make it sit at 63ish wms wms
thecarman said:Do you mean C&C hubs, as in Cab & Chassis?
Pinkston said:Cool Project. I have a set of C&C hubs if you need them.
drkelly said:That is some good work dude and some funny about the unplugged saw. What tires/wheels you going to run? Keep the pics coming, looking good. How much trouble did you have with the inner C on the 60 when shortening? I have read many posts about it being difficult. I'm going to be interested in seeing your plate job and diff cover on the 14B. I am too chicken to cut mine like that. How much do you estimate you took of the ring gear?
You need these now with the new axles:
http://muddevils4x4.com/forum/viewtopic.php?t=269
DK
drkelly said:How much trouble did you have with the inner C on the 60 when shortening? I have read many posts about it being difficult.
DK
wbcarver said:Please don't say you just cut the tubes and welded them back together.
Tuite said:How are you going to make the pinion flanges? Turn down the ears off of the 1310 yoke and turn out the center of the toyota flange, press fit it, then weld?
