propain ?
1badrig
Member
Abingdon
ok i have a yota buggy with 22r motor in iton propain yester day i was climbing a hill almost strait upand was just sitting there spinning and all of the sudden it started pouring the smoke but then quit is that normal when ur on a verticle angle like that 4 a while
you are dumping oil on top of the piston the good is propane will run at any angle. your engine will not. don't stay on extreme angle's for a extended amount of time and you will be fine. other wise you will be replacing a motor.
as said, propane will run at any angle, your engine won't. Make sure you can kill it when you need to
