Ricky B
Wiiide Open
- Mar 20, 2005
- LKN - Tha Dirty Mo (Mooresville, NC)
As you guys probably saw from my other thread i'm getting ahold of a caddy 500, currently in my chevy i've got a 350 runnin on pane. Know I know just about nothing about pane setups as the truck already had it installed when I bought it. I'm wondering if it would be possible to swap the current pane setup from the 350 onto the caddy 500. From what I've heard the caddy 500 stock carb pushes bout 700 cfm, will my current pane setup push enough pane to quench that? If you need to know model/size or w/e from my current pane setup let me know where to look for it on the parts cause I don't know where it would say and what to look for, allthough I think John said it was a impco 425?
My next question is how does pane work in comparison to gas? Like when driving does the motor act any differently than if it was runnin on gas? With a close to 500 ft lb motor is pane gonna make it run just as good as gas would, not gonna rob any power properties is it?
If pane isnt the way to go then I also have a holley projection setup I could use, I think its only rated to handle small blocks though.
Is a holley 770 truck avenger gonna be my best bet?
Thanks
Thanks
