The big one is the WOT screw.. If your stuff is working right, it won't affect anything until you're WOT. open that one up a 1/2 turn until WOT acceleration doesn't get any stronger.. That's the poor man's approach.
Your idle mixture (the thin one off on the side) is what you want to do to keep the raw propane smell to a minimum.
Between idle and WOT, the mixture is totally controlled by the amount of air the engine is drawing, and the Impco gas valve. Don't go looking for a new gas valve. The one in yours should run your engine fine.
There's a ton of info here :
http://fuelsforum.rasoenterprises.com/viewforum.php?f=5
there's also a site like franzh.texas.net that has a bunch of propane info.
P.S. the screws are just like a carb. in is less, out is more. However, unlike a carb, too rich doesn't keep things cooler...
Yeah, shoving a sniffer in the tailpipe and dyno tuning it is the best thing, but that's up to you.
P.S. Read up on re-curving the distributor.. it can help.
