For your engine I would recommend an Impco 225 mixer(carb) a Model E converter, and a Your choice of lock off, either vacuum (VFF)or electric.
You will need an adapter to mate the mixer to your intake(goes between your mixer and the base plate of your carb.
Vapor hose to connect the mixer to the converter.
The converter has to be in line with your heater hose(keeps it from freezing up and ceasing operation)
Then you need propane supply line to your lock off, then supply line to tank(s)
Tanks of course, I recommend two tanks, but a lot of folks only use one.
You will need to either fab up, or buy tank hold downs.
All your supply hose and fittings can be bought at a local forklift supply place. You can also get with Kenneth, 4x4girl, on this board. He has a lot of pane stuff and has fittings and hose in stock. He may even have the adapter you need. He, as well as gamedog of this board has tanks for sale too.
Hope this helps
