EvilEric
Member
- Jun 15, 2009
- Salisbury, NC
What are the pros and cons of using propane? Its for my trail only Raider carburated 4cyl. Just wondering if its worth it or not. How hard is it to do? etc.
pro,s:cheap and very reliable.if its not injected go with the propane set up.What are the pros and cons of using propane? Its for my trail only Raider carburated 4cyl. Just wondering if its worth it or not. How hard is it to do? etc.
All other things being the same, you will use more Propane than gasoline. The average calorific value for motor fuels vary a good bit but here is a list of minimum accepted values:yeah i been wondering the same. at work the fork-lifts really burn it up quick. how long will one tank last on the trail?
hey chip i sent ya a couple messages but never heard from ya.not sure if they made it or not
#2 Diesel Fuel - 128,450 BTU/Gal
Gasoline - 116,090 BTU/Gal
LPG - 84,250 BTU/Hr
It will take more propane than gasoline, and more gasoline than #2 diesel to do the same amount of work. Propane has a higher octane rating than gasoline. The higher octane rating of the Propane gives you the ability to play with the engine's timing:
Gasoline range 80-88
LPG 97
If you buy propane from a propane distributor, and not at a BBQ tank filler, the lower cost of the Propane should offset the greater fuel consumption. When bought at a distributor, Propane should be 20-30% lower than gasoline (no hghway taxes).
I am a gas controls engineer, and I also rep a company that produces LPG conversion systems for fuel injected engines.
