Clubbs
- Jun 15, 2008
- Blounts Creek
The original brake proportioning valve on my CJ started leaking out of the check valve pressure blow off ball thing. I can't find a parts store that has a replacement.
Factory power brakes work great with the d60/14bolt brakes (rear are still drums). But now the rear leaks down.
What's the recommendation? Find one that looks the same (probably a gm unit knowing amc) or go fancy wilwood adjustable thing-a-ma-bob with a removable check valve to go disc later?
It's nearly impossible to get to and I'll probably have to cut the original lines off it so only want to do this once.
