MR. GADGET
- Apr 5, 2005
- Raleigh NC
So anyone found an easy way to pump the oil to the gears and trans without an little hand pump?
I was going to build a PVC tube with end caps and ball valve with a hose and air fitting then just fill it hit it with a little air and open the valve to let the oil out.
I'm sick of the little hand pumps you got to hit 1000 times and the electric or crank pumps you loose a lot of oil in the pump. No real room on the tow rig to get in there with a bottle and hose plus the redline oil has a small cap that will not fit to anything.
