Either
a) your windshield needs to lay back a little bit further,
or
b) you can loosen up the bolts that go through the hinge and into the door and pivot the door up. You'll just have to compromise on the gaps all the way around. But be careful after move these, you most likely will have to adjust the door striker pin so that it will still shut and latch correctly
