question about wranglers
EL XJ
Charlotte NC
I need a part for a friend that has a 95 Jeep Wrangler 4 cylinder, from what to what year can i look for a part in that year. 91-97? Needed is a lower alternator bracket. Is this also something that would be found from a cherokee. thanks
4-cylinder MPI engines were used in the YJ Wrangler from 91-95. A carb'ed 4-banger was used 87-90, might have the same bracket, might not. XJ's also used the 4-cylinder, but the alternator bracket could be different due to a different belt drive layout. You might have luck in the 97 and up TJ Wranglers.
