**89mightymax**
- Feb 21, 2010
- taylorsville
ok so i have a cobra classic LTD i have a 2 peice 10 ft coax and 8 1/2 ft steel whip. what does it mean when i get a red ant. light when i key up?
Not trying to prove right or wrong here because I used to think the same thing. The 3' increment thing is an old CB wives tale. Check this out for good reading:Measure the coax again,coax HAS to be in 3ft increments! You have to check the swr, swr needs to be at 1.5 or lower,antenna ground is critical. Don't operate till it's right or you can ruin the CB.
