drkelly
Dipstick who put two vehicles on jack stands
- Mar 21, 2005
- Oak Ridge/Stokesdale, NC
The fiancee and I are looking at a piece of land for sale that has a pond on it. I don't know anything about ponds, so I am looking for some help/advice. It was definitely man made, and judging from the size of the trees on the dam it must be at least 30+ years old, maybe even 50+. It appears to have a pipe running through the dam, and also what looks to be an auxiliary storm drain run off area around the edge of the dam. The water is slightly murky. I have read that there are things you can add to the water to clear it up. I went for a swim off the dam to check the depth of the water, and it went over the 8' pole I was holding very quickly. From looking off the back side of the dam, I would guess the pond is probably 15 ft deep, or at least it was when it was originally built. I am guessing it might have silted in a little over the years. It appears to be fed by a very small creek/drainage. We have not had any significant rain out our way in almost 3 months, so the creek/drainage has limited water in it. I would estimate the size of the pond at about 2 acres. What kind of things should I check for or be aware of?
Thanks,
Danny
Thanks,
Danny
