Think I have an issue with my DD Blazer. Replaced the passenger side CV axle and when I put the assembly back together and bolted the wheel back on, the wheel would not free spin. Had both front wheels in the air but the driver side wheel would spin by hand and the passenger side would only rotate a couple inches side to side. Could not get it to spin anymore than that no matter how hard I tried. Both front wheels would free spin fine before I changed the CV axle. I compared the new and old axles before I replaced it and everything looked to be the same.
I can drive the truck and it doesn't pull to the right. I've replaced the front brake calipers and hoses a few weeks ago. The wheel bearings seem to be fine. Can wiggle the wheels and the bearings have no play in them.
I've also noticed a roaring noise from the frontend, that varies from high to low frequency. It's pretty much a constant noise when I drive it. I can also feel it in the floorboard of the truck while driving. Noise has started after I swapped in the new CV axle.
Just put new wheels/tires on it, Rough Country lift with new upper A-arms and balljoints, front end alignment just done, etc. Alignment shop didn't find any worn out suspension parts.
Anyone have any ideas?
