Ridgerunner
- Mar 21, 2005
- Fuquay Varina, NC
Ok then Here you gosaf-t scissors said:If either one of you can explain to me how a radiator cap that isn't designed to open until the coolant temp reaches 255F allows coolant to freely pass back and forth at 195F, I'll kindly STFU.
Until then....
Wel First I think you are getting the Radiator cap and the thermostat confused becuase the Radiator cap has a pressure rating not a temp rating.
Pressure builds up in the radiator and after the pressure gets to the rating of the Radiator cap then it opens and then and lets fluid into the over flow Bottle.
Now it shuts after the pressure is relieved. When the engine starts to cool down it creats a suction and opens the little valve in the center of the cap and sucks the fluid back in. see picture #2. When presure is higher in the radiator the little valve is press Shut againest the rubber seal.see pic #1
So There you have IT
No Radiator Caps wer harmed in the creation of this post
