Chuckman
- Oct 9, 2005
- Huntersville
Ok heres the deal. A stock D30 for a TJ has a 5 link front. 4 arms and a trackbar. If you look at all of the radius arm setups that are offered aftermarket, they use the stock upper mounts cause they are there- and those uppers are mounted inwards. I understand why there are like that due to the way the spring/shocks mount up and the low stock stance, but is there a benefit to mounting them inwards if you were to lift one? I guess what I am asking is if you lift one 4" and were to do an axle swap, would it be necessary to mount the uppers inwards? I have mine setup with a radius arm and the uppers are in line with the lowers and it seems to work like a charm. But this was dumb luck as I did not have any other way to get around it- 60' chunks are biiiiigggg. I am looking at putting a HP D44 in a TJ and have a descent way to use a cast C axle, but I dont want to fab a mount for an upper on top of the chunk and want to use both uppers. I know about the whole binding deal with a double upper design, and I wonder would a set of uppers mounted inwards help this effect similar to a wishbone rear upper? But wouldnt they have to be touching in the center to benefit fully? Anybody have experience either way.
All of this assumes that I wont hit the uppers on the frame at full stuff and only 4 inches of lift....
