rear disc on yota axle
BIGWOODY
Thomasville
Need to put disc on the rear of a mini truck axle. Whats the combination to set this up? Is it a trip to the parts store and some caliper brackets or what? Thanks, Greg
-Caliper brackets from whoever
-1984 MonteCarlo Calipers ( or El Dorados or Caminos or...all the same...Dorados have E-Brake I think)
-softlines for above caliper
-I've used 91-ish front half ton chevy rotors...gotta get the center hole enlarged to fit over the axle shaft flange though...the dimensions on pirate in the Toyota FAQ I think...
in short...http://www.pirate4x4.com/forum/showthread.php?t=281059
greg, i used the sky mfg brackets, they work well, pretty cheap. 82 monte carlo calipers/pads, and the rotors....
gotta get them for an early 90's chevy 1500. they offer 2 versions, you need the "non heavy duty ones" they are thinner than the reg. I get mine at o'reily's.
sky also sells the rotors...already turned. Not that it is a big deal to find someone to do it...
I am running Skys full kit with the monte carlo calibers...
you can also use early 90s model pathfinder calipers, rotors and back plates becuase the pattern is the same and the shafts are the same diameter..
