I see all of these rear/mid engine buggies being built, when you turn the motor around and mount them in reverse (facing out the back). Are the gears reverse cut in the axles or t-case since the engine is theoretically now spinning opposite direction for being mounted 180 degrees from pointing forward or are the gears in the trans just working opposite-like to go forward is reverse gear in the trans, and to go in reverse is drive or am i just over thinking this. This is just a question, that has been bouncing around for awhile.
