Milk Man
- May 29, 2006
- Stedman,NC
I need to test the motor and see theres 2 wires on it. Is one a hot and other ground and do you switch the leads to make it go up and down. I am passed the point of pi$$d on trying to get it to work. I got it last month and the guy said it never worked when he had it. The switch is broke and I think the relay is bad. I was going to try to run a 3 way switch and straight wires back if it will work. Has anyone here had a problem with the rear window. Thanks
