heres the tech data
#200985: 2003 JEEP GRAND CHEROKEE 4DR SUV
Audio/Mobile Video
WIRE COLOR POLARITY LOCATION
Battery RED/WHITE (+) RADIO HARNESS
Accesory WHITE/RED (+) RADIO HARNESS
Ground BLACK (-) RADIO HARNESS
Dimmer ORANGE (+) RADIO HARNESS
LF Speaker (+) LIGHT GREEN/RED OR (GREEN/ORANGE) AT RADIO HARNESS
LF Speaker (-) LIGHT GREEN/GREEN OR (BROWN/RED) AT RADIO HARNESS
RF Speaker (+) LIGHT BLUE/RED OR (PURPLE) AT RADIO HARNESS
RF Speaker (-) LIGHT BLUE/BLACK OR (BLUE/PINK) AT RADIO HARNESS
LR Speaker (+) DARK GREEN/WHITE
LR Speaker (-) WHITE/DARK GREEN
RR Speaker (+) WHITE/VIOLET
RR Speaker (-) TAN/DARK GREEN
Radio Security YES
Security
Battery PINK/BLACK OR (RED) (+) IGNITION SWITCH HARNESS
Ignition 1 DARK BLUE (+) IGNITION SWITCH HARNESS
Starter 1 YELLOW (+) IGNITION SWITCH HARNESS
All Door Trigger YELLOW
YOU MUST DIODE ISOLATE BOTH TRIGGERS TO MONITOR ALL DOORS. *SEE DOCUMENTS
Domelight Super YELLOW/DARK. GREEN (-) AT THE BCM ABOVE THE DIAGNOSTIC CONNECTOR
LF Latch TAN/RED (-) AT THE DRIVERS DOOR LOCK SWITCH
RF Latch TAN/RED (-) AT THE PASSENGERS DOOR LOCK SWITCH
LR Latch TAN/ORANGE (-) AT THE BCM ABOVE THE DIAGNOSTIC CONNECTOR
RR Latch TAN/YELLOW (-) AT THE BCM ABOVE THE DIAGNOSTIC CONNECTOR
Trunk Trigger TAN/BLACK (-) AT THE BCM ABOVE THE DIAGNOSTIC CONNECTOR
Alarm Disarm LIGHT GREEN/ORANGE (-) AT DR DOOR LOCK SWITCH 463 OHM RES.
Parking Lights YELLOW (-) AT VEHICLE LIGHT SWITCH
Low Crr Pk Lights YELLOW (-) 1K OHM RESISTOR AT THE STEERING COLUM HARNESS
GROUND THROUGH A 1 K OHM RESISTOR
Convenience
Headlights-Lo VIOLET OR VIOLET/RED OR (YELLOW) (+) AT FUSE JUNCTION BOX
REQUIRES A 330 OHM RESISTOR THROUGH GROUND. IF YOU USE AN 80 OMH RESISTOR IT WILL TURN THE PARK LIGHT AND THE HEADLIGHTS ON.
All Hazrd Lights DARK BLUE/PINK (-) STEERING COLUMN HARNESS
Wipers-Lo GREEN/RED (-) IGNITION SWITCH HARNESS
Remote Start
Accessory 1 RED/BLACK (+) IGNITION SWITCH HARNESS
Accessory 2 BLACK/ORANGE (+) IGNITION SWITCH HARNESS
Anti-Theft Type SENTRY-KEY
Anti-Theft Descript AN RF SIGNAL ACTIVATED SYSTEM
Neutral Safety YELLOW (+) IGNITION SWITCH HARNESS
Tachometer TAN (AC) AT MODULE NEAR DRIVERS SIDE OF FIREWALL
THE 4.7 HAS SEPERATE COILS, USE THE UNCOMMON COLORED WIRE. DO NOT USE THE DARK GREEN/ORANGE. THE 4.0 HAS SEPERATE COILS, USE THE UNCOMMON COLORED WIRE. ANY TAN/STRIPPED COLOR WIRE WILL WORK. OR USE THE UNCOMMON COLORED WIRE AT THE FUEL INJECTOR. DO
Speed Sense WHITE/ORANGE (AC) AT THE PCM LOCATED ON THE RIGHT SIDE OF ENGINE COM
Low Crr. Pk Lights YELLOW (-) 1K OHM RESISTOR AT THE STEERING COLUM HARNESS
Brake Lights WHITE/TAN (+) AT SWITCH ABOVE BRAKE PEDAL
Reverse Lights VIOLET/BLACK (+) IN HARNESS IN PASSENGER KICKPANEL
Horn GRAY/ORANGE (-) IN STEERING COLUMN HARNESS
Modules
WIRE LOCATION
Please select another category
Doorlocks/Windows
Power Unlock PINK/BLACK & PINK/PURPLE (REV) AT MOTOR IN DOOR
PowerLock ORANGE/BLACK & ORANGE/PURPLE (REV) AT MOTOR IN DOOR
Driver Mtr Unlock PINK/BLACK (REV) AT SWITCH IN DRIVERS DOOR
Driver Mtr Lock ORANGE/BLACK (REV) AT SWITCH IN DRIVERS DOOR
Pas Mtr Unlock PINK/PURPLE (REV) AT SWITCH IN PASSENGERS DOOR
LF Window Up LIGHT BLUE (REV) IN DRIVER'S DOOR
LF Window Dn WHITE (REV) IN DRIVER'S DOOR
RF Window Up BROWN (REV) IN PASSENGER'S DOOR
RF Window Dn VIOLET (REV) IN PASSENGER'S DOOR
LR Window Up DARK BLUE (REV) IN DRIVER'S DOOR
LR Window Dn RED/WHITE (REV) IN DRIVER'S DOOR
RR Window Up GRAY (REV) IN PASSENGER'S DOOR
RR Window Dn DARK GREEN (REV) IN PASSENGER'S DOOR
Note: Audiovox makes no representation or warranty with respect to the above information including its accuracy, completeness, or its freedom from third parties' proprietary rights. Audiovox disclaims all liability or responsibility for errors or omissions therein or any decision made by the recipient in reliance thereon. The installer must verify any circuitry with the proper test equipment prior to installation.
