Removing stock sway bar linkage
I've had the best luck getting them apart by wedging a pickle fork or screwdriver and prying them apart while hitting the stud on the swaybar link with a hammer. If you have one available, a small pitman arm puller would be your best bet though.
I can't get the stud out of the swaybar. I can get the links off the axle but not the swaybar. 4wp said to just hit it with a hammer after PBBlaster but the studs still won't budge:mad:
If you need a picture I can txt you some
x2 on the pickle fork
i had to take a dremal with a cut offwheel to the swaybar links and used a screwdriver to pry the collars apart thats how badly seized mine were
