Repairing cracked alloy rim?
Caver Dave
Just holdin' it down here in BFV
Moderator
Hooterville (24171)
So, had 3 of the 5 alloys on my DD bent (2 "surgically repaired") but anything over 65mph was shakey... so, bought a used set with good tires.
Put them on and one wasn't holding air. Pulled it off to find a fawkin' radial crack in the bead area! :mad:
Any chance it can be repaired or start hunting for another single unicorn to match the other 3?
Try some bead sealer first?
get some steel wheels. thats what i did on the wifes DD. damn potholes and dogs pissing
on the original aluminum ones did in 3 before i got em changed out. 2 got cracked and one
was so corroded from dog piss that it would not hold a bead.
I would say your best course of action is to drill the end of the crack, and cut into the wheel with a cutoff, along the crack, so all "cracked" material is gone, then filling it. Then grind/cut a groove back into your weld and reweld, as most of the impurities from the casting will probably rise to the top of the first weld.
