- Mar 10, 2005
- Hooterville (24171)
So, I have a small (15' wide x 50'-ish long) spring pond up the hill from the house. It's got a single 4" black corrugated drain that sits horizontally, that runs about 20gpm 24/7 unless it's pouring...
It does pretty good most of the time, but highly prone to clogging from leaves (both floating & waterlogged) and when it does clog, the spill over is eroding the dam... IMHO, it's sits too high and is lets the level get too high. Rather than continue cleaning (in vain) every few days or risk it washing out the dam, I'd like to modify a bit.
My short-term thoughts are, extend the corrugated further into the pond and turn it up vertically (using a engineer stake) and use a taller chunk of 6" PVC over that with random holes in the *middle* to allow the water inside, but keep the leaves (floaters/sinkers) outside.
Any cons against going this route temporarily?
Longer term plan (read: Spring = warmer, hopefully not as hectic as the past few months) will be to replace it all with 6" PVC... potentially spinning a small alternator to charge a small battery to power a few strings of LED's lighting the path top said pond/fire pit area...
