Rhino Liner
duke343
Raleigh
I have been debating whether or not to rhino line my 98 Wrangler. I have heard the pros and cons to lining, but there seems to be too many options to make up my mind. If anyone could supply some info about which stuff works the best, or if I should do it myself, and if not who should do it?????
Do not go to the rhino place off capital. They still haven't gotten mine right on my truck. I would do the Rhino again but from the place in garner. I have also heard great things about LineX. When the LineX guy quoted us he rattled the price for a wrangle off the top of his head so I would guess he has done a few. You will get a better price if you pull everything but the drivers seat. I would not put Herculiner in it. It is cheap, but doesn't measure up in durability or protection.
Alright sounds good but how do I get in touch with this guy from Garner? To pull everything does that include the console?
I had great results from rolling on herculiner myself. Some people have had problems with it as stated above, but I think it has to do mainly with people not following the application process properly. I spent 80 bucks and a weekend's worth of work and it has held up great. And yes you have to remove everything, even the console. Some go so far as to remove the roll cage. Here's mine for example.
I had the guys in Garner do my F250. I have ripped, burnt, dammaged, and destroyed my liner. I took it back for repair, and all they did was put some sort of caulk in the holes. They say it is 1/4" up to 1/2" thick, but I have seen mine is no where near that thick. Also things slide arround on mine. Not quite the liner (or waranty) they brag about.
Friends of mine have Linex. None of the problems that I have had
Does anybody know how I could contact the LineX guy in Raleigh?
Line-X of the Triangle 919.785.3337
4120 Pleasant Valley RD. Raleigh
Behind the Walmart on Glenwood ave, past the rental trucks.
Tell Mel that Kevin sent you.
personal friend of mine, known him for several years, does an outstanding job, and stands behind his product, sometimes even on top of it ;)
Kevin
