Jeffncs
- Apr 4, 2017
- Wake Forest
Installing a pre-bent 6-point family cage into my early bronco. This one is a sunny day “round town” cruiser. Bronco 2 will be a little more interesting build….
Thinking about adding center spreader bars (blue tape as mock up) for a ceiling mounted stereo head unit. I’m not tying the hoops into the frame but am adding oversized plates under the floor to sandwich the new steel floor panels.
Questions:
Should I add the center spreader bars?
Should I add corner gussets? Flat plate cut to fit? Or use 1.5” 1/8” wall tube at each corner?
Truck goes to paint in a couple weeks so trying to get the cage finalized so I’m not welding over fresh paint.
Thanks!
Edit to add - the side bars have more clearance to the driver than it looks…. Guessing 4-5” diagonal.
Questions:
Thanks!
