Scotch Block from Bailey's
Wake Forest
Tell us what you think...
Bailey’s Scotch & Snatch
m2
The Bailey’s Scotch & Snatch is designed for light duty towing applications with front and/or rear mounted winches. It was developed for the towing industry and is easily adapted for personal and recreational recoveries. It uses no chains or anchor points and doubles as a wheel chock while improving stability during recovery on any surface type. It is a compact design for easy storage; folds to 14.5" x 12.75" x 4.5" with 1 pin making it very easy to use. The Scotch & Snatch is corrosion resistant and made in the USA, start to finish. It allows you to use your truck to its fullest potential, doing more with less. There is an optional tire strap kit available for soft ground and/or larger tires.
Retail: $480.00/pair
Special NC4x4 Price: $384.00/pair
Call 919-562-2984 to order.
Some YouTube videos:
Tow Trucks:
http://youtu.be/A5f-Ei9TaKw
Some fun in the mud:
http://youtu.be/lB_uD14WQRs
Toyota FJ using the Scotch & Snatch:
More info at:
http://www.baileystowinginc.com/
Don't forget to take a look at our 4.5 Ton Snatch Block!
