Will Carter
- Mar 23, 2005
- Burlington
Moved to new shop.
It's got 3 legs of (measured on cheap meter) 118v.
Cross over any two legs I get 211v.
I've only run one plug at the moment. The mill works fine on 3 phase. Starts, stops, reverses...
Started on a project and my buddy was the first to weld something. Said along the lines of "Your welder settings are all off." I figured they got bumped in the move so didn't think any of it.
When I finally see that he's welding on 5 what I normally weld on 3 I started checking it out. Sure enough that's the case. I'm welding on 5 what I used to weld on 3.
It's like I'm lacking power.
I had also been fighting the plasma cutter on the CNC table. I just thought I had damp air (hadn't hooked up the dryer yet) and wrote it off to that...
Never checkd the voltage at the old shop. Can't now 'cause the powers been disconnected.
What am I missing?
What am I missing?
