RatLabGuy
- May 18, 2005
- Churchville, MD
Have a '93 Toy Xt Cab that will hopefully become a new race vehicle.
The wheelbase is crazy long, 122". Belly drag city!
I'm debating shortening it by 12" or even 19" to about the same as SWB trucks.
I see the following steps needed:
- bed will come off.
- I'm thinking I'll cut off the front/rear leaf spring hangars and move them forward. May change to late 80s springs which are a little shorter.
- replace driveshaft; it has the double-cardan style now, will prob re-use the CV at the output end
- have to shim axle for now angle
- make/mount new bumpstops
- move upper shock mounts forward
What other problems arise from this that have to be dealt with?
One thing I see is that moving the front spring hangar forward on the frame puts it farther "downward" along the curved part, maybe even to where it is horizontal to the ground (like happns w/ the 63" chevies).
On one hand this will natively add some lift (good), but also change the operating angle of the leaf spring, so that instead of being mostly up/down and slightly forward at full flex, it'll be angle more rearward.
I guess some longer shackles would help deal with that?
Anything else?
Anything else?
