I assume you mean a racing style harness with two belts going over your shoulders. If so, then the answer is no. Not unless you want to cut a hole through your seats at about shoulder height.jput said:does anyone know of a manufacturer that makes a shoulder harness seat belt that will work with factory TJ seats???
Yeah, I wasn't condoning cutting the seat. I do agree that he should get a seat designed for harnesses.Rich said:Doubt you'll find anything.. you should really go with a seat designed for harnesses if you're gonna run 'em, or at the very least, a seat with a flat top to it...
Even if you were to cut a hole, you need a frame just under that to prevent the belts from crushing your spine.
This isn't really something to just be slapped in..
Rich said:Even if you were to cut a hole, you need a frame just under that to prevent the belts from crushing your spine.
Rich said:I can't predict whether I'm gonna take an easy flop, or a Real TV-worthy 4 roll with a half twist off the side of the hill...
Here's another side of it.. if you weigh 200 pounds and take a good endo, I'd bet you land with 2G's or so of force.. 400lbs pressing on you.
This is an eternal debate about how well a rig needs to be built, and it certainly won't be ended here... it's pretty obvious where I stand on the matter just by looking at my junk.
Never heard ANYONE say "Man, I wish I bought cheaper safety gear" after a crash/roll/flop though. Besides, my Corbeau's are cooooomfy!
ShyHiK5 said:1 honest reason i havnt is finding a restraint seat made for a FAT ASS is not an easy chore, corbeau used to make a wide option (I had in my first hot rod) but according to their web site it is no longer offered....
