smoking vacuum lines
Discussion in 'General Tech' started by GotWood, Mar 2, 2010.
  1. GotWood
    GotWood Sayer of Fact
    Jan 12, 2007
    Maiden, NC
    I'm having problems with my wife's Intrepid:shaking: again, but at least this one doesn't seem to be too serious. I am throwing a 441 code. I have heard you can use a machine to pump smoke into the vac system to find leaks. Anyone here do this??
  2. 3DCrawler
    3DCrawler Well-Known Member
    Sep 26, 2005
    Granite Falls, NC
    I'm in Granite Falls but yes we can check it out for you. Give me a call if you dont mind the drive. 828-396-7071, Minton's Automotive
  3. 1stgenxxx
    1stgenxxx Well-Known Member
    Dec 19, 2005
    Hudson
    You can use Oxygen too....or either
  4. Jeff B
    Jeff B pool boy
    Dec 23, 2006
    Lincolnton N.C.
    I have used a hand held propane torch to find vacume leaks. Idle the engine & allow the gas from the torch to blow (slowly) around the vacume lines. When the engine idle goes up you have the area you leak is in.
  5. marvilusone
    marvilusone Well-Known Member
    Oct 21, 2007
    Cleveland, NC
    I do the same thing but with starting fluid. Also cleans your engine off at the same time
  6. Hurdt299
    Hurdt299 Well-Known Member
    Nov 13, 2006
    Asheville, NC
    This method works great. Just make sure the torch isn't lit. :rolleyes:
    I've seen people burn wiring harnesses up using this method.
Share This Page
