AZOnslaught
- Jun 29, 2008
- Fayetteville
Okay,
For those of you have read my previous threads, I have asked some "nubieish" questions concerning axle swapping, spring hangers, etc.
My Jeep is in the frame state with NO spring or shackle hangers and I have option to do what ever I want since its a complete built. Problem is that I'm now on a time crunch before having to move back to AZ per the Military. Leaving in November 15th and I have to have a rolling chassis by Oct 31st so I can tow it. I have purchased Dana 44 axles from a 1990 Waggy (Thanx to 1BIGAZZBURBN) and now I need help figuring out what I need to do to make it work ASAP. Pictures will be greatly appreciated
The Idea is
37'', Street and Trail Drivability, Stock tranny and Xfer case on a YJ.
My problems are
1) Shackle Reverse, I have read that for street drivability it might not be the way to go.. What mods will I need to do to incorporate this with SOA and DANA 44's? And should I even bother?
2) Dana 44 front and rear SOA. The front is my main concern. I have measured the springs, perches off the OLD and NEW axles and BOTH are measuring 31” from center spring to center spring. DSD and the spring lands on the outer tube of the Diff. I have read people welding perches on to that and or grinding a pad into it. Best practices please..
I have been advised that I should outboard my springs for both or just SOA application but I have researched and I have found nothing of that nature.
All Help is GREATLY appreciated! And if I have overlooked anything please Please Please let me Know!
Thanks!
The Idea is
My problems are
Thanks!
