raleighjeepguy
- May 27, 2007
- Raleigh,nc
B/C I really am! So I'm planning on slapping an 8.8 in the rear of my jeep within 2 weeks or so. I need a lil more lift on my jeep right now and soa seems to be the way to go in every way possible. I've read about 2000 write ups but and maybe its just not soaking(since Im retarded) so if I could run some stuff by you guys and see if I've got the just of it..
Front
axle:d30
*basically weld the perches parallel to the existing perches. Caster should stay the same and everything is happy?
*I've heard the stock steering will hit and some say its fine. Troof?
Rear
axle: 8.8
*Install sye and cv shaft with pinion of 8.8 pointed directly at the output of the tcase.
*tack perches upon load being put on and everything bolted up.
Anything else I need to consider. I know its not supposed to be this straight on but it seems simple in my mind. Any problems or advice would be appreciated. Btw the packs will be stock yj with an add a leaf. Heard it works well. Troof?
Front
axle:d30
Rear
axle: 8.8
