soft door question?
2020GLADIGATOR
Raleigh, nc
the origional owner sold the soft doors to me with the jeep. since its getting warmer i figured i would use them to see if i liked them, the thing is, the door latches dont line up. is there another door bracket that needs to be installed for these to work. more information: i have full hard doors cause i have a hard top. thanks
justin
well if im not mistaken, i thought the TJ had diff latches then the YJ and CJ... and that the TJ's latches were higher up, but that the doors would fit, with some modifications to the latches
I used some YJ doors on my TJ for a while. I made a new catch out of some strip steel and 1" pipe. I had to grind down the the pipe a bit, but it worked just fine. I think I still have these in fact.
Im doubt what i have will work for your jeep but you probably have the correct handles i need for my YJ. I got a used super top with 2 piece soft doors that use to be on an older CJ. If you find the correct handles for yours i would be interested in buying yours if they are actually what i need.
