Chuckman
- Oct 9, 2005
- Huntersville
so if you don't know me, Im 100% hard on my shit. If it breaks, I upgrade and go on about life. I hate replacing stuff over and over wondering why it keeps breaking. so after installing my NV4500 behind my 6.0 I was completely happy until the shitty stock slave cylinder blew its seal just 300 miles in. so after going around and around with the asshats over at Advance Adapters and a total of close to $1200 to put in an external slave, I thought there had to be a better way to put in an uber reliable throwout bearing and not cost that much. BTW, AA really has no idea what they are doing regarding the late model LS engine, its truly remarkable. They can set you up with parts if you do the research yourself but if you call them, they are all like uhhhhhhhhh. no way Im supporting that. anyway, I found Ram Clutches out of SC. Guess what? they make a rebuildable billet internal throwout bearing for chevy transmissions that isn't cheap but its TOTALLY badass. sold through summit, you've got the last throwout bearing youll ever need, if in the wild chance that it fails, they already sent you new wiper seals and orings for the first rebuild. their unit for the T56 bolts right up to a chevy NV4500 and matches 100% correct to the displacement of a CJ iron duke hydraulic master cylinder. no mods necessary and is smooth like warm butter and as easy to install as it is making fun of Fuller. very, very happy. No heat or clearance issues with an external slave, and its not plastic. get ya some -3 AN fittings and you have a bullet proof setup. cast iron master, braided stainless hoses, and billet aluminum internal slave based on factory design. what more could you want? the end.
