SOLVED
Backwoods boy
CORNBREAD KILLER
NWNC
X
The only other thing I can think of might be the heater for the choke. (If you got one) Are you running the stock Alt? That can kind of be a PITA. Also there is a tach lead from the ignition module under the coil. It will be a single wire going to a green connector.
Good thread on the Pirate board about bare minimum wiring.
