I am making good progress.
Just wondering. The inner pinion bearing race (the bearing that's pressed on) has a thin metal thingy behind it. Is that the inner pinion bearing oil baffle? And how am I supposed to remove the race without destroying this thing? Also, isn't the pinion depth set by using shims behind that race? How are you supposed to repeatedly install it and remove it when setting up gears?
