Someone to bend 3/16 plate 90 degrees
ProbablyBroke
does not torque to spec
Reidsville
I have a plan to flatbed my toyota. Acquired a 49" x 83" sheet of 3/16" steel. I need someone with a press brake to bend it in two places. 2-90 degree bends. call text or reply on here.
7o4to7799for6
Located in Waxhaw NC, 20 miles south of Charlotte.
Scott at MudPro can bend but only short lengths unless he has new equipment.
Look around for an industrial fabrication shop. Most will be able to handle it.
I'd call AME in Charlotte. They have a press brake that can handle it, no problem. I've used them in the past and they have been pretty good.
www.ameonline.com
Almost any local steel supplier and any large fab shop will be able to do that. Like Rockcity Rob said, unless Scott has moved into a much larger shop with much larger machines, that's too big of a bend.
On another note, that is one hell of a heavy flatbed for a yota--that's quite a bit thicker than what is used on actual 1 ton work truck beds.
I can get any of this bent. I have access to a 16 foot break capable of breaking 1/4 plate full length. Pm me for details.
