- Mar 24, 2005
- Stanley, NC
I'd like to find a chart or some solid numbers of the continuous torque rating for spider gears. Mainly D30, D44, and D60, since I happen to have those sitting around.
I have this crazy idea, but it just might work.
I want to build a PTO reverser for my tractor. Not anything I can shift, just something that I can put inline between the PTO and the implement shaft.
If I had a housing with an open carrier, carrier held in place, I could plug one side into the PTO, and have a PTO like output on the other side that rotates in the opposite direction.
It could be simplified even further by eliminating the housing, and turning down the ring gear mounting face. It would have to mount to the tractor somehow to handle the torque, but that would be a simple bracket.
If I were confident that a set of spiders could handle 300ft-lbs continuously if kept in an oil bath, I might start thinking seriously about this. My tractor is 35hp, so thats about 340ft-lbs at 540rpms. While that wouldn't be the continuous load, certain activities would probably see 2-300 ft-lbs continuous (tilling).
My biggest concern is that the spiders wouldn't last with constant rotation. In a rearend, they spend most of their life just hanging out, not doing much. Rarely are they subject to continuous turning and loading. If you are spinning your tires, they aren't loaded, and if you get traction, they stop spinning.
Anybody got some numbers or thoughts for me?
