Kap10merica
- Feb 19, 2011
- Canton, nc
putting a spool in my front diff is that a good ideal or should i go with some kind of locker?
if it turns great then you better check you'r frount end because something is broke.IMO there is no catch all answer. I run spools in the front of my race rig and trail rigs. They all turn great and will turn circles inside most locked trail rigs. My combo of choice is spool front, ARB rear with rear cutting brakes. I run spools in both ends of my race rig for dependability. The A class Cherokee I am building now will be welded in the front D30 with upgraded shafts, ball joints and steering and a rear LS 8.8 with cutting brakes. If the rig is built with a combo of parts to all work together, performance will be good. If you're going to run a spool in front you better have the parts and steering to back it up.
I do have a 44 in the front but after reading all these comments i"ll be buying a locker.Thanks for the help
am i the only one that is not understanding this? not trying to be a smart a$$,just confussed.I would never put a spool in a D44 front and certainly never in a rig that sees any street driving.
Spools work for me, my car and pretty much every Jimmy's ULTRA4 race car. It's all about the system not the components. I've had about every locker/axle combo out there at one point and I like spools the best. Can't break em, the $1k saved over Detroits can be tossed into making the axle turn 45+ degrees and they are predictable in performance.
My car and Cherokee will be in Auburn next month, come drive em and you will agree it flat out works well. I'll even supply a few cold pepsis and some cough syrup.
