Wwildman
Never Give UP
- Apr 16, 2005
- Garner, NC
Here is my score of the day ant the local j/y I found a dana 30 teraflex steering knuckle . Here is the issue someone drilled out the taper on the drag link tie rod and put a hime joint there with a large bolt .Not sure of size bolt it and rod end was missing .
Does somebody make a tapered sleeve to put a 1 ton tre in it ?
I know I could put a rod end there but I would prefer a proper TRE for it .
